- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
i found a spacer kit with no shaft you can view the instuctions on pdf it said to get a shaft out of a car tranny with a 6in tail and measure from the center of the speedo gear clip hole out to 31/4in and wrap tape, and cut off 13/8in including the saw blade. now is the T/C bolt pattern the same for the 350 and 700r ?
That sounds right to me. You see the chunk I cut off, it's about that long. I know it's between 1in and 1.5 inch, so 1 3/8 is probably good and it can be off by 1/8 too. yes, the Th350 and 700r4 are the same bolt pattern so they share the same Tcase adapter. All you need to worry about is getting the output shaft the correct length and use that spacer and you're good to go. It's very easy.
