- Sep 8, 2019
- Northern Wisconsin
- Taylor
- K10, K25
- 400(?), 350
picture?Hi, I am new to this forum. I have a 1982 Chevy G20 vans with a 350. I discovered the hard way that you want an air cleaner that has a blue/grey coloured ring which appears to be a carbon filled device which is permanently sealed into the air cleaner base. I removed mine as I thought this was a restriction to air flow (which it is) I soon discovered a problem though. My gas tank began to crumple as the vacuum from the fuel pump on a sealed system was not allowed to equalize. I replaced all kinds of things including the vapour canister and still had the problem until I realized that the grey restrictor ring that was originally in the air cleaner was there to provide a small area that was not under vacuum. This was how GM/Chevy had their system set up to be compliant to hydro carbons being contained. So if your vehicle is California compliant you may want to make sure the air cleaner you look for has this intact.
Glenn
