yevgenievich
- Mar 1, 2014
- Texas
- Viktor
- sad
- very sad
- less sad
Might have wrong geometry on the carb bracket
Are mostly all edelbrock G- brackets kinda the same? Im not sure what model my carb is. I was told a 750 cfm but that's about it. I know that have a few 750's but would the bracket b e the same? Maybe I should just grab the geo-bracket and mounting bracket just to be safe? They look pretty lvl with eachother in the photo.Might have wrong geometry on the carb bracket
After looking at you setup it seems like your setup is not right.Is there some kind of other adjustment on the carb thst could be too tight causing the cable locking mechanism to keep stripping? Could the plunger on the tranny cause this? My gas peddle is really tight and not because of a heavy return spring or whatever its called.
A little later then it was. Something like 18mph (hard shift) well firm 40mph (softer shift) I think. Had a shift kit installed when I had the trans rebuilt. And the dude put a vette servo in as well. If that sounds right. I could be messing up what its called.How's it shifting now?
Sent from my LG-LS993 using Tapatalk
