700R4 TV (Throttle Valve) Cable Adjustment
Scubasteve4848
Maine
steve
K10 Silverado
has anyone installed an edelbrock performer 600 carb and performer intake on a small block with 700r4 xmission? i bought the TV cable adapter and installed ad adjusted according to GM spec. it seems as though the TV cable is loose. i havent test drove yet, but the xmission shifted way to early and slipped if matted before the TV adapter was installed. the TV cable was tighter before the adaptor was there. should it be tight at WOT? i'm thinking i need to get the eddy throttle/ TV cable mounting plate to get it placed right to adjust according to GM specs. anyone have any thoughts?
74 Shortbed
This is the cable bracket I had on mine along with the Edde carb adapter, sorry that's the only pic I have and my truck is all apart right now..
gVyrus
Maryland
Kevin
5.7L
I have a 750 and intake on a 400sb with a 700r4. Oh and update... Wouldnt matter how I adjusted the cable slipping damage was already done probably due to poor cable adjustment by previous owner so sent it out for performance rebuild.
Be sure you have the Geometry correction for that Carb or you'll trash this new one too.
74 Shortbed
Correct geometry bracket.
gVyrus
Maryland
Kevin
5.7L
Is this rite?
MikeB
North Texas
Is this right?
If you have a 700R4, any slack at all is BAD! That's because at very light throttle, the trans still needs increased pressure. I recently had a problem with a friend's car where there was too much slack. It turned out to be the TV link rod was getting hung up inside the trans end of the OE-type cable, causing the inner cable to not pull all the way out. It would have been a disaster had the car been driven that way. The throttle valve MUST start moving at the slightest hint of throttle movement.
gVyrus
Maryland
Kevin
5.7L
I have no slack in the cable. It starts to pull the cable immediately when acceleration begins. My question is what would make it reset itself and pull itself out by itself in the picture after being set? It did that to me last night for some reason.
350runner
tx
Ceasar
It's not locked properly.
Sent from my LG-LS993 using Tapatalk
gVyrus
Maryland
Kevin
5.7L
Hand to forehead... Duh. Can you tell I'm new at this? Lol sorry for the dumb question.
74 Shortbed
Make sure the locking tab comes all the way back and the adjuster is not stripped.
350runner
tx
Ceasar
No question is dumb[emoji16]
gVyrus
Maryland
Kevin
5.7L
It shouldn't be stripped. Its a new cable but I guess anythings possible.
gVyrus
Maryland
Kevin
5.7L
Is there some kind of other adjustment on the carb thst could be too tight causing the cable locking mechanism to keep stripping? Could the plunger on the tranny cause this? My gas peddle is really tight and not because of a heavy return spring or whatever its called.
lepak
