2wd dually with Cummins swap
NJakey
Southwest Virginia
Nick
Custom Deluxe
Considering purchasing this 2wd dually w a Cummins swap. Engine has close to 200k and trans has 32k on rebuild. Seller wants 5500. Worth it?
In the PNW, you'd pay that much for either the engine/trans OR just a normal running CC in decent shape. For a CC with a 12v Cummins swapped in and probably a NV4500, that seems like a heck of a deal. Especially if he is asking for that off the bat. You should be able to haggle him down a little more and get a screaming good deal.
NJakey
Southwest Virginia
Nick
Custom Deluxe
He was asking 6500 and I worked him down to 5500. Just thought I’d ask for some advice from my square body friends before I pull the trigger
Honestly, if a CC cummins swap is what you have been wanting, I doubt you would be able to build one for anywhere close to that price. And it is already running and driving, with zero time invested on your part. 200k on the motor is nothing, that thing is barely halfway through it's life.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
It really depends on the workmanship. If it's done well and reliable, and with documentation, because you're not going to remember what pieces were installed, then it would be a good deal.
Was the 200K miles put on the engine after the install? That would say a lot about the reliability and workmanship.
NJakey
Southwest Virginia
Nick
Custom Deluxe
Yes, after install and the gentleman has owned it for 20 years and has every receipt. That’s what really peaked my interest. It needs body work obviously, but seems to be in top mechanical shape
80BrownK10
Greenwood, SC
Nate
I'd say that's a good price. That truck could sell for anywhere from $2500-5000 without a Cummins swap, depending bon the seller. That swap would cost almost that much I would guess depending on parts sources. I think that's a fair deal if it's done half decent .
Diesel K30
Washington state
Nick
Toyota Sequoia
Yea I saw in the Tri Cities for 8500 and was considering buying it. And it still needed a lot of work (dented in doors and had a 3 speed non overdrive automatic transmission with 4.56 axels... that puts you at 59 mph at 3k rpm!)
Sent from my SM-G930V using Tapatalk
dob555
