2bbl on a 454?
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
someone told me its possible to put a 2bbl on a big block is this even true?
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Are you wondering about fuel mileage on your truck?
GothRod
You can buy an adapter to put a 2bbl on a 4bbl manifold. Easy swap. Then send me your 4bbl lol jk
-John
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
454 has to breathe!
Thats like removing a lung!
jake wells
Can i be me?
jake
custom deluxe 10
hey know i will trade this edelbrock carb with adapter plate and chrome air cleaner for the stock parts :wave:
its a 750cfm maybe trade for a two barrel
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Im not posetive on this but your truck should have come with a quadrajet right?
82chevy350
Van Buren, AR
Joey
C10, K10, K5
It would be like sucking air through a coffee straw
85k10383
Glengary, WV
Ross
K10 Scottsdale
On the bright side, it would probably fix your gas mileage, because you wouldn't want to drive it that way LOL Weren't the later Quadrajets set up to run on two barrels most of the time anyway?
jake wells
Can i be me?
jake
custom deluxe 10
guys im pretty helpless as it is when i bought the truck it had a edelbrock on it which somebody told me is to big for a bone stock 454 he said it need a 650 not a 750cfm
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
According to what i read online a quadrajet like the one in my 85 will get beter mileage than a 2 barrel as long as you drive it easy and keep from opening the secondaries. I also read its a 750 cfm if the demand is there, it meters depending on the need for fuel. Do a google search and check it out.
GothRod
I dunno, I think people rely too much on internet CFM calculators now-a-days. Sure, a 600 will work good on a stock 454, and probly increase the throttle response, but it should love a 750 as well. I really think a 2bbl would limit rpm.
FWIW- Irishman is right, Q jets are 750cfm(800cfm one could be found on some bigger engines like my Cadillac) so GM must have thought 750 was about right lol Thing with a Q jet is that the secondaries are vaccum op(on demand), so you can't hardly bog the engine with too much gas. With your Edelbrock(mech op) when you floor it it dumps all 750CFM worth of air & gas at once. If you don't have enough motor you get a bog.
A good condition Q jet thats off a 454(for tuning reasons) would be the best of all worlds, power+economy. I'm sure you can find someone who will trade you a nice Q jet for your Edelbrock.
-John
82chevy350
Van Buren, AR
Joey
C10, K10, K5
id find at least a 700 or 750 quad or a 600 1406 edel they are mad for fuel economy the edel would be better than that 2brl
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
-John
This
Reason why the Qjet is my favorite carb.
They'll give you better economy over Holleys
and a properly tuned one can give you great performance
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
This
Thanks Manbearpig, i cant recall anyone else agreeing that a quadrajet is a good carb. If you pull one off and look at the baseplate you notice its a perfect setup, smaller secondaries for cruising and when you demand power it has HUGE secondaries. I drove my buddies truck with the 2 barrel on a 305 and mine seems to have alot better power just cruising around town.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I didnt like my Q-jet offroad, steep banks would dump the float bowl, load up and kill the engine. Sometimes that can be a really bad thing. I tried the bowl vent extended tube mod but still had drown-outs so went with the Edelbrock 600cfm 1406. Installed the offroad kit, tuned the primary needle-and seats, secondaries and accellerator pump and been running happy for many years. But this is on a 350, I've always heard 750 was for high-performance smallblocks and for bigblocks. I think Edelbrock also makes a vaccuum operated secondary carb.
3dbello
