Nasty-LSX
TogetherforeverCovid19
- Nov 22, 2014
- HOUSON TX
- Mi Hung Lo
- c10/k10/k20
- LSX
I am finally getting around to the 4x4. She has been neglected for some time now. Been doing alot of LS swaps for everyone else. Now im taking some time for my own rides.
Long story short, I burned up the transmission in my 06 short bed single cab 5.3 4L60e silverado.
I made a 200 mile trip pulling a car trailer that weighs about 2100 LBS Empty. on the next 200 miles back with just a car shell, total weight maybe 3500 LBS is when i burned it up.
MY GOAL!! Swap a 6.0 with a BUILT 4L80E. Trans will have all the goodies.. 6.0 will have full bolt ons
with the truck intake still installed. I will have a custom grind cam for good power and TORQ!! engine should be in the power range of 400 HP or under to the rear wheels. Not building race truck. Just want a good cruiser and hauler that can pull 5000LBS easy.
I will say it has a stock GM GOODWRENCH 350 replacement engine done years ago with a turbo 400 trans.
It will pull 5500LBS with ease. The only reason I dont use this truck is because I get about 9/12 mile per gallon. Pulling is even WORSE!!
Will I have any problems running a 208? I have read the 241 TC is a upgrade from the 208 and all bolts up the same. Im just trying to build a STRONG RELIABLE truck to pull short and far distance with decent mileage. Not a off road or rock crawler.. Thanks!
