1983 c30 dually dual tank efi questions
Jokerz49
Timothy
C30
Hey all. Have a few questions. Recently bought a 83 c30 originally with dual tanks. (Only had passenger side when I bought it). I'm looking at adding the drivers side tank and going from carb to the holley sniper 2 efi. I don't believe is has the charcoal cannister anymore so should I change out the fuel sending unit to 2 hose or keep them 3 hose?
Also how did you guys run 2 electric fuel pumps for this? Can they be wired into the tank switch or should I run a separate on off on switch for the pumps?
And what hoses do you recommend to run? I know I'm gonna need to run stronger hoses to deal with the pressure.
Any help will be appreciated. And please explain thoroughly as I had a tbi 4 years ago so I don't comprehend fully.
Thanks
MarineOne
Western New York
They have a couple nice options for dual tank efi I recommend the dual pump option but single setup works too
I like ptfe an style fuel lines but rubber an lines work too but the ethanol in our fuel will eat them eventually
Jokerz49
Timothy
C30
Ok thanks I will look into those hoses and run 2 pumps. Just still trying to figure out how to wire the pumps so they only run depending on tank selected.
MarineOne
Western New York
The efi pro kit has the full wiring setup you need and the correct tank selector valve so it returns to correct tank aswell everything you need in a kit
If you already have pumps you can buy the harness and valve separately
darrel
