New For Me 1985 Silverado 20 6.2 Diesel
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If it gets cold where you are, the diesels had a pickup sock with a relief valve for when the fuel gels up. You're going to want that. I don't know the part number offhand, but I'll see if I have one at the shop so I can get a picture for you.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Oh lookey! It turns out I do have the part number:
The end of the strainer has the valve. It looks like a fuel pump check valve, just oriented so that suction will pull it open.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Well poo Derek, I can not find anything local, but could order
Poo Derek, can't find anything local, only online. I have a very tight schedule, so will install and plug it in this winter. However you have been a help in the past and I appreciate it
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Plugging it in is not going to help because the sock plugs up in the tank. The only fix at that point is warming up the tank itself.
Additives will help lower the temp where gelling occurs. When I've had the misfortune, it was at about 15°. But additives need to be added when the fuel is above freezing in order to mix properly. The warm return fuel, and the temp of fuel in a in-ground tank is usually okay to accomplish that if you add it when filling up. But once the fuel is gelled up it's too late.
So, remember to use your additives (which you should always be doing anyway) and you should get by until you have another chance to get in there.
Craig Nedrow
Washington State
K10, K20, C20
Finished wire brushing the frame, degreased, and painted. Also painted some under the hood. Thanks Craig85 for the paint tip, covers fast, and has the look I am looking for.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Power services makes really good Diesel additives.
Power Service, Alliant Power, Stanadyne,... Any of those is fine. I hear that Howe's is good too. Never worked with that particular brand, but I've heard good things.
Craig Nedrow
Washington State
K10, K20, C20
More done, trying to figure out the fuel switch wiring. My bro helped me test the original switch, and it was bad. Gas tanks ready to go, but holding until the wiring is completed. Can't get enough wiggle room to get the instrument panel to trace the wires. The 73 I can pull it out far enough to release the speedo so what a bugger. Also installed the new radiator, and it was also a bugger, took four hours, but it should last the rest of my life. I might be able to access the under dash area from the radio area, as it is coming out to get repaired by Joe. A few pics.
JoshinIT
