A/C Condenser Mounting Insulator
crooney1189
FL
Carl
Having trouble getting a hold of the (4) rubber insulators as well as the (2) metal "cups" that mount the top of the a/c condenser in the core support for my '86 C10. I'm adding a/c to my originally non-a/c truck, so I never had them to start with.
Does anyone have a lead on them? Or an alternative solution to mounting a factory a/c condenser? I'm finding zero references or part numbers, and I even started searching under GMT400 trucks. Starting to feel like they're unobtainium.
RaisedK5
Leland
Blazer
They should just be well nuts. Available in the weird hardware and assorted dodad drawers of any decent hardware store. ACE or True Value. Not so much the big boxes
Edit: I looked and stand corrected. Home Depot carries them.
crooney1189
FL
Carl
Ah, thank you!
This is the condenser I bought, so maybe I'll make something like that work through the flanges instead of trying to use the top and bottom "feet".
loki1978
