79-80 Dana 60 Front Axle brake parts
1outtacontrol
Red Deer, Alberta
383 Stroker
I’ve got a Dana 60 Front Axle part number 610057-8 which when I look up is a 79-80 GMC front axle. How do I figure out if it’s a 3/4 ton or 1 ton axle?
I’m trying to buy rotors calipers and pads but need to know if it’s 3/4 or 1 ton. I bought the axle by itself so not sure what vehicle it came out of and wishing I would’ve kept the old parts from when I stripped it down and had it blasted and painted.
nvrenuf
Mobile, Al.
GM front D60's were only used in 1 tons so use a K30 as your application.
For GM, front D60 parts are pretty much all the same. The original inner axles will have a necked down area whereas the '81+ are fat end to end, the length and spline are the same throughout.
HOTFOOT
northwest ct
michael
gmc k3500 srw
If you look at the front cover next to lower right corner has a size I’d cast in. This is my 80 gmc k3500 Dana 60 single wheel, all my brakes came from rock auto
88SQDRW
