Don5
- Oct 5, 2014
- West Virginia
- Don
- k15
Thanks Don
I am gonna order all my bushings from energysuspensionparts.com They have everything I need. In fact you can buy every thing you need to replace every piece of rubber bushing on our trucks for $300 or less. That's pretty good and I like the idea of all red bushings.
Also almost any speed shop can order them if you give them the part #s
I have never seen shocks come with boots but they will sell you them for $3 a boot. they come in packs of 2, in almost any color. I always use the boots. But I make sure that there is always a drain hole below the cylinder to body seal. In fact I never even get moisture inside the boots unless you submerge it in mud or water. So for DD use, boots work very well. If you nick the cylinder the fluid can leak out and then your shock is done. So I use the boots and my current shocks are 7 years old and work like I bought them yesterday.
Also it seems to me that the cheapest and best bang for your buck are the Pro Comp ES3000 shocks usually about $50 a piece.
I am pretty sure that is where I got my front bushings from. In the old days, back in 1985-86 when I bought my kit, you got to choose which color you wanted for your shock boots. It seems that is not so common anymore. I think it is because it costs money for the manufacturer.
I just replaced all 10 of mine last year. I have always used them as well. I got them from Summit.
