WTB Orig. Exhaust Crossover '87-'91 Blazer/Jimmy
mrdap
C/K_Lover
C20/K30/V15/V2500
Hello Again!
Here's another strange part I'm looking for...
GM original
Exhaust pipe, crossover
'87-'91 V1(16) (Blazer/Jimmy)
L05/5.7K, 15549058
Maybe you trashed your original stock system and went to headers and true duals.
I'm looking for this OEM GM part in good condition without any damage or modifications.
Thanks in advance!
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
I just checked mine out today for you and its got two small dents. The shipping would of costed you a arm and leg though to get it you. I actually had quite a few of your parts but sent them to the scrapper unfortunately. I am curious on what your building though.
mrdap
C/K_Lover
C20/K30/V15/V2500
Hi thanks for your response.
I might be interested in the crossover pipes anyway If the dents aren't too bad. I understand about the shipping.
Maybe you can shoot me some pictures when you get a chance.
I'm a big square body guy and I have quite a few projects.
I tend to focus on keeping things original. I had a very bad experience with a transmission repair shop. My transmission went out in my '88 GMC Jimmy. No reverse gear. Didn't have time to do it myself so I took her to a transmission shop. They repaired the transmission and 6 months later it failed again in the same way. They did cover it on warranty and repaired it again but the second time they did it they cut my crossover pipe and welded it back together.
I was very angry about this.
It was a pristine pipe. After the second rebuild again it failed about a year later. No reverse. If I start out and drive or OD, the transmission will not downshift into first. I have to manually put it into second gear in which case it will start out in first and then shift into 2nd. Then I have to manually put it into third and fourth.
Anyway I'm just trying to get it back to where it was before they hacked on it. I'm also converting this '88 GMC 350 to a serpentine accessory drive.
The other project is my 82 C20 454. I just want to convert that to a serpentine accessory drive. 329,000 miles.
My latest acquisition a '91 V2500 Suburban 3/4 ton, 4WD, 350, 4L80E. Previous owner butchered front hubs and bearings.
Rebuilding all the front hubs and brakes.
This one came with the 40 gallon tank but no skid plate and no gas tank protector so I'm just upgrading.
mrdap
C/K_Lover
C20/K30/V15/V2500
Still looking for:
GM original
L05/5.7K, 15549058
mrdap
C/K_Lover
C20/K30/V15/V2500
Still looking for this exhaust crossover
I have a 87 Blazer I'm sure is stock. You want the Y pipe? I'll have a week of vacation at the end of the month, my plans are to pull the motor and trans out, I don't know what condition it is in, I haven't spent much time under the Blazer yet. I can get you some pics if you want.
mrdap
C/K_Lover
C20/K30/V15/V2500
Hello Mr Clean..... Thanks, sent you an IM
Got the Y pipe out today... got you some pics... It's a little crusty, a wire wheel would take care of that. I didn't see any dents or dings. I would cut the cat off of it before i would mail it if you want it. LMK.
Ivys
