- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Wrench/Socket Size & Tool Guide
I am going to make a log here of the tool sizes needed that I documented in some of my write ups so that it may help somebody else as a guide to have things ready instead of guessing and climbing under a truck or into an engine compartment with the wrong size tools.
These sizes are from a 1989 GMC Suburban V-1500 5.7L TBI 700r4. May vary from year to year or on other models.
Engine Compartment
Battery
Battery Terminal Bolt - 5/16"
Battery Hold Down Bolt - 1/2"
Motor
Negative Battery Cable Terminal and ECM Motor Ground Terminal and Rear Tensioner Brace Bolt (Located in front of thermostat housing) - 9/16"
Rear Tensioner Braces - 9/16"
Alternator Positive Cable Stud - 10 mm
Brake Booster Line to TBI Unit - 3/4" & 5/8"
Intake Manifiold Mounting Bolts - 9/16"
Heater Core to Manifold Pipe Fitting - 1 1/16"
Distributor Hold Down Bolt - 9/16"
Distributor Cap - 1/4" or Phillips Head Screwdriver
Ignition Coil Mounting Bolts - 1/2"
Fuel Line Bracket on Left Rear Head - 1/2"
Fuel Lines to TBI Unit - 3/4" & 5/8"
Crusie Control/Throttle Cable/Trans Cable Bracket - 9/16" & 1/2"
Center Bolt Valve Cover Bolts - 10 mm
Thermostat Housing Bolts - 9/16"
Water Pump Bolts - 9/16"
Fan Shroud Bolts - 10 mm
Tensioner Pulley Nut - 5/8"
Clutch Fan Nuts - 1/2"
Exterior
"Paddle" , "Big Guy" or "Dumbo" Mirrors
Outer Cover - T-20 Torx
Adjustment Bolts - 10 mm
Drivetrain
Front Suspension
10 Bolt Axle Cover Bolts - 1/2"
10 Bolt Axle Fill Plug - 11/16"
Rear Suspension
Rear Shock Upper Mount - 11/16"
Rear Shock Lower Mount - 7/8" & 13/16"
10 Bolt Axle Fill Plug - 3/8" Square Drive
Transfer Case
Fill/Drain Plugs - NP241C Transfer Case - 1 3/8" or 1 3/16"
Fluid Capacities and Types
NP241C Transfer Case - Dextorn Mercon II - 3 Quarts
10 Bolt Axle Rear - 80W90 GL5 - 2 Quarts
10 Bolt Axle Front - 80W90 GL5 - 2 Quarts
Engine Compartment
Battery
Motor
Exterior
Drivetrain
Front Suspension
Rear Suspension
Transfer Case
