Would be interested in thoughts about tonneau cover options for a 79 longbed.
ron1445
Charlotte TN
Ron
Thinking I would like a folding hard cover, but interested in pretty much anything that others might have already done… even homemade or custom…
Keith Seymore
Motor City
Keith Seymore
4.3L
I have some thoughts:
1 - I wouldn't do a one piece. The 2015 I just bought had a one piece on it and the problems were two fold: a - if you had to haul something that wouldn't fit under the cover then you'd have to take it off. That could be a one person job, with some cleverness, but was basically a two person job. b- then, once it's off, you've got to store it somewhere. Then it's definitely a two person job to put it back on.
Plus - it traps the tailgate. So you have to lift the cover every time you want to open the gate. If it's cold and the latch freezes then you are done until it warms up.
I was in Pennsylvania helping my daughter move back and the furniture didn't fit. I ended up leaving the pickup cover there in the trash because I knew I was going to replace it anyway.
2 - Four folds are probably better than three folds. The smaller sections are easier to deal with. But - here again - if you need the full length of the pickup box in order to haul something then that first section closest to the cab will block you and you'll need to remove the whole cover (unless it is the kind that flips vertically after storage).
My hard cover got damaged and became waterlogged. The interior was a combination of plywood and styrofoam so it didn't hold up. Further attempts to repair it with aluminum sheet were clunkly and didn't last.
Which brings us to today:
3 - I ended up going with a soft rollup. It does what I want, plus rolls into a small area on top of the pickup box panel. Unrolling it allows it to clip into the end of the rails, and velcro holds down the side.
I haven't had to haul anything yet but I see no reason why this shouldn't be fine.
One piece cover shown first (disposed of); roll up cover from the Summit catalog. https://www.summitracing.com/parts/trx-272401
Truck82
Alderton
Christopher
I always liked this one. It looks good but is truck specific. I don’t think that would work with any color truck besides brown… it’s an idea at least.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Our truck originally had the typical upholstery shop riveted snap vinyl cover.
Other thn the shop's sloppy workmanship it was a great thing.
More recently I bought an Extang rail system cover. I tried modifying it for the cross-bed toolbox by shortening the bed rails. Then I needed an upholstery shop to shorten the cover.
Right. :rolleyes:
Anyway, when I need to buy replacement bed rails many years later,...
There are plenty of dealers and the parts are readily available. Highly recommended.
For practical purposes, there's much to be said for the practicality of soft vinyl covers, depending on the fastening system. They have their drawbacks, like weak support for snow, and lousy temperature properties. But I'm very positive about soft vinyl covers as the best compromise, and Extang is a great company to deal with.
sherrodmachine
