Snuffy Smith
- Dec 2, 2023
- Canada
- Snuffy
- C10 Scottsdale
- 5.3 LS
I have been digging through old posts on the major Square Body forums and going over wiring diagrams to try to find an answer, so far I have not found exactly what I am looking for. Background on my truck, it is an 86 Scottsdale with a 5.3 LS, TH350 and a 75 front end swap making for some interesting wiring combinations.
I am trying to sort out the wiring for the horns to get the truck to pass safety and on the road; when the front end swap was done, horns were not installed so I am tracing the wiring to find the horn wire. Looking to ID the wiring in the pictures, Im a little cautious about wiring and would appreciate some expert input.
Fairly certain I have the plus for the trans lockup here. Necessary for a TH350?
Im having trouble tracking down this relay block on the driver's side of the wiper motor on the wiring diagram I have. From tracing wires, I am pretty sure this is the hot wire for the cigarette lighter, wanted to confirm this. There are a couple pictures below of the wire path.
The red wire from the relay block runs through the firewall grommet into the cab; unfortunately, the wire was cut inside the cab and not connected to anything, but has enough length to reach the cigarette lighter.
Any insight would make this process a lot easier and would be appreciated.
