oldspwr
- Jan 4, 2019
- Daleville, PA
- Tom
- C10
I am looking for some help with a wiper issue on my Brothers stepside squarebody we are restoring. The cab, wiper motor, steering column, turn signal switch, etc. is from a 1985 GMC K30. So it has the external windshield washer pump. The original motor was badly rusted so I purchased a new WAI motor from Amazon. The wipers park fine, but when they restart, they go down a bit before going back up. In fact if the wipers are parked in the correct position, they go down on the painted cowl piece before going back up. So my first thought was that the wiper linkage was installed incorrectly. So we flipped the linkage and then the wipers parked in the top of the windshield instead if the bottom. We also added a separate ground wire to the brass strap on the motor to make sure it was grounded correctly. It does have the intermittent (delay) box under the dash, and the delay seems to work. I did remove delay box and plugged the two connectors together and we still have the same issue.
So we bought a new motor from Napa, and it does the same thing. Then we bought a Cardone from Rock Auto and that does the same thing. When we set the new motors side by side, it seems the park positions are all a little different. Does anyone have any thoughts on this? Any help would be appreciated!!!
