window switch color code
:party33: :party33: :party33: :happybday: :happybday: :happybday: :party33: :party33: :party33: :cheers:
mouthpear
Here
YourFirstNameOnly
big
Maybe you missed this (it was under the wiring diagrams):
Notice that in both systems the black wire (that heads down to the motors) is shown to be grounded - apparently to a 1/4" stud on the motor frame.
As confirmation that the black lead is intended to be grounded to the motor frame/mounting bracket, here is the wiring diagram for 1981 model year. The circuitry is still the same, but on this dwg it clearly states that the black 150 lead is to be grounded to the motor bracket:
How do the black leads - in the harness that you have - terminate? Is there a ring terminal on the end?
BTW: It's probably just a typo, but the way you describe the motor up/down power leads is backwards:
I know dk blue and brown is pass side and blue white stripe and tan is driver side
All the schematics I have looked at have shown:
1. The LH (driver's) side motor being supplied by the dark blue/brown pair
2. The RH (passenger's) side being supplied by the tan/dark blue- white pair
Not to sound ungrateful but I can't see anything in that image. Can't read any words. Can't make anything out at all. Is it just me? Can you repost? Please.
jimlayhee
