- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Praise Jegs. They sent me a new one for free.
reinstalling this weekend. Any suggestions for materials or designs for making an exhaust heat shield?
Yes, use aluminum sheet. Easy to cut and bend. Aluminum grabs the heat fast, also releases the heat fast. For brackets use flat steel. Bend a 90 degree or what is needed on each end. Drill holes in those bent ends, bolt to holes in the shield and whatever you find close by. Size to fit. Two brackets will work, three is best. You may even find a spot where you can just bend a corner of the sheet aluminum, and bolt to that.
