Who sells the best replacement gas tank
dusterdude
US
mark
gmc c15
1985 gmc 305,recommend the best quality and fitting gas tank available.thanks
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Spectre is pretty good. If you ever plan to do EFI or in-tank pump you can get an 87 model year tank and it comes with internal baffles.
I would definitely do 87 tanks.
edgephoto
Stafford, CT
Greg
GMC V3500
7.4L
I just replaced one of my tanks with a Spectra I got from Rock Auto.
SirRobyn0
One of my tanks is original the other is spectra. Both my sending units are spectras as well. I'm also installed a few tanks and sending units at the shop into squarebodies all have been spectra units and none of them have ever had a problem. So I would trust that brand for sure.
But I also like to mention that gasoline doesn't like moisture, and neither does metal. So if you are replacing your tank or tanks because they are in bad shape on the inside make sure your evap system is working properly. Besides controlling vapor off the fuel the system prevents moisture from getting into the tank.
dusterdude
US
mark
gmc c15
Thanks guys,ill take a look at spectre
dusterdude
US
mark
gmc c15
Actualky,i realized i bought a spectre and had to trim the seam a bunch.now it leaks,thats why i need another
83Stepper
Massachusetts
Chad
Pretty sure I've got an GM11B in mine from Spectre. Seams were a little on the elongated side when putting my new tank straps across it. But nothing a rubber mallet and a deadblow couldn't handle. Bought it off Amazon for a better price than I could find anywhere else.
dusterdude
US
mark
gmc c15
I looked at the amd,nice looking tank.ill check out dorman also
Camar068
10 yrs Air Force
free shipping as well
BrokeDaddy
