SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
Yup. 283, 305, 307....all fun to drive until you're friends find out.A 307 is like an ugly girl...they are what they are but get the job done! Put a new timing set & seals in it & punch it hard enough to moan like it's a 4bbl. That's how I treat my 283!
HS
Ive put 4 barrels on sbc that were running 2barrels before. It's still fun but of course they are limited on flow with those heads. I ran 650 4 bbl carbs on themA 307 is like an ugly girl...they are what they are but get the job done! Put a new timing set & seals in it & punch it hard enough to moan like it's a 4bbl. That's how I treat my 283!
HS
That was kind of the plan. 929 cam,performer and an edelbrock carb.I'd run the 307, but definitely swap a small 4 barrel or preferably a quadrajet on it. I believe with the appropriate 4 barrel, you'll get better mileage, throttle response, and more power.
The 4 bbl primaries qjet are smaller than the 2bbl primaries. So slightly better mpg with the 4. If ya keep your foot out of it!Not meaning to cause thread drift, but the 74 C10 I have with a stock 350 2bbl gets about 11mpg.
My 1980 K15 350 quadrajet gets about 14+.
On a weekend toy or part time driver, I don't think it matters much.
350 or 327 block with a 283 crank gets you a 302 or an early 283 block .120 over. It was scca and they had to be under 305. And the reason the 302s were so bad was they built them out of the baddest 327 they had,they revved so high because that cam acted bigger in the smaller motor. 327 crank in a 283 block is a stroked 283 in other terms the 307,I think they are 330s with a 350 crankA 327 crank in a later model( post 1963 I think) 283 makes it a 302.The Z28 was designed that way to be able to compete in some type of race years ago, I cant remember exactly.SCCA trans am series I think
