Which Wiring Harness Question
19kilo76
Baton Rouge, Louisiana
Nathan
scottsdale
Ok wiring harness question. I have the frame and engine from a 76 K10. I purchased two rolling chassis parts trucks (for $500 total) 81 and 85. Both cabs are in great condition. What wiring harness do I go with in regards to the engine cab? I am probably going to go with the 81 cab. Any advice regarding this matter would be greatly appreciated.
On a side note, the 81 does not have a title but the 85 does. I might us all I can off the 81 and keep the 85 for a future build with my son. He wants to lower a square body, I don't plus I have a K10. you don't lower a k10! LOL
yevgenievich
Place
Name
Year
Model
Size
I would choose the harness that is in a best shape and use gauges/switches that go with it. I did 91 harness in my old 85 and used the gauges and sensors from 91. Your wiper and high beam switches will move location. Steering column can be swapped as well
hatzie
k20
I'd consider the 1985 cab if they are both in good shape.
The 1985+ washer pump in the reservoir is less expensive than the earlier gear driven pump.
Creature comforts like intermittent wipers are easier to add to the 1985+ stalk controlled wiper setup and the later pulse switch is a bit more reliable.
I believe the AC controls on the 1985+ cabs are vacuum controlled.
The wiring and service manuals are in the library. 1981 wiring is in the back of the service manual.
GorillaHumper
