What wheel center?
Magna86
VA Beach
Magna86
Chevy 350
I have 15x6 or 15x7 steel wheels on my new project. But I don't know if these fit the same center as the 15x8 rallyes or take a center hub cap for the lug area. Here are what they look like. Mine have a beauty rim on them too. The truck originally came with PO1 Bright Metal Wheel whatever that was. Thanks
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Should still fit just fine if the lug spacing is the same and they bolt up to the truck. I don't believe there is anything special about the hub area of the Rallye wheels. You will have to drill holes for the caps to screw into though, they're not held on by the lug nuts. They just used big self tappers from the factory so you won't have to worry about threads or anything. Just line them up, drill some holes, screw them on and enjoy
FireTruck1984
Michigan
Ted
1984 and 1984
I’ve talked with guys who run rally centers on their 15x7 plain steelies
It’s a cool look but you will probably have to drill and tap holes to accept the caps
Magna86
VA Beach
Magna86
Chevy 350
Thanks alot guys. I'll run the steelies with the caps until I find some 15x8 rallies.
Littletrucker
