89GMCJimmy
- Mar 5, 2019
- ivan
- Jimmy
I know you already purchased parts, I made the mistake by buying AC Delco Gold/professional parts they were cheap chinese and had play in them so I had to do my front end twice stick with OEM AC Delco or Moog. If you havent installed yetYeah I only do Moog, Proforged, or AC Delco parts for this stuff. When you buy a complete control arm does it also include the bushings and all of that stuff? Is everything pressed in and installed to the control arm also? Seems easier to just replace it all and not have to fiddle with grinding stuff out and pressing things back in. Can you remove the control arms both upper and lower without removing either ball joint, that would be preferred for time.
