uh huh.
@Frankenchevy ...yessir, some ****...
higher numbers burn longer for more ignition advance.
the letters are the tip/ insulator style or whatever. Some other difference.
I can remember the R45TS used to be something different, it wasnt always them letters because WE used to run different plugs and by we I mean every reader of this thread, but whenever that change happened I already knew that it was the plug I wanted to run at +1000 feet in a SBC. So I just started using the new number t45ts..
The engine didnt change, what they call the spark plugs DID, however. Aluminum heads are different.
You don't remember when platinum plugs busted onto the scene and disrupted that entire industry?
I was working at Andy Granatelli's Tune-Up Masters around then.
So?
So it's no different than H-Pipe location or how long of a header collector is best...not any different really.
If you can't fix a Honda, you ain't much of an auto mechanic. Youknowwhatimsayin?
Pretty much all the same. There are many.
In most applications haha...our 30-40year old trucks probably have the right ones in em already lmao. Indexing aint gonna make a crap light to light even if it
does add one horsepower. WASTING TIME costs money.
If you live in a colder climate , or use forced induction/power adders, you'll need a colder range (often smaller number) spark plug because less ignition timing and lower operating temps.
But reallly it aint gon make much a sh*t.
As long as you run SBC iron heads the TS tip is what u want.
BUT , for example, the aluminum Corvette heads for the Camaro use a 43 some other tip letters because the spark plug length and its colder because aluminum. it gots an L.
Whatever. it's a square. I'm too tired to argue again over $10 worth of spark plugs lmmfao.
