What tdc tool do y'all recommend?
Dutch Rutter
Independence, Or
Joshua
In a pinch, I've made my own in the past. Butchered up an old spark plug. Put a bolt through and taped the bolt threads so it wouldn't scar the top of the piston. Worked pretty well.
My last build i bought on off summit and it also worked great. It was like this one (not this actual one but close)
https://www.summitracing.com/parts/sum-900189
Rickf
Grafton NH
1974, 1954 & a 1937
I made one out of an old spark plug, cw then ccw method. The $8.50 tool wasn't available when I needed it.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I remember one that would whistle when you were on the compression stroke. Then you could find tdc once you knew you were on the right stroke. Didn't see it though. It'd be helpful sense im doing it by myself.
78C10BigTen
pennsylvannia
C10 BIG TEN
I've generally just used a screwdriver, kind of old skool I guess!:cheers:
I always used to pull the hot lead off the distributor that way it cant pop off, then pull the #1 plug and put my finger on the hole. Have a friend bump crank it till it blows my finger off the hole then rotate ccw till it was perfect.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Yep, I've done it that way before but, I'm all alone on this one this time. Maybe get lucky if a neighbor can help me out.
Octane
Atlanta
Eddie
I stick a small *** of paper towel or tissue paper in #1 and turn till it starts to blow it out,then just turn till its on the timing mark.
louu
South NJ
Lou
C3500
454 for now working on LS
If your just doing it to get the distributor in and get it running. I've always just put it to where I thought top dead center was and then took a piece of 3/8 fuel line, stuck it over the spark plug hole and blew into it. If you can't blow into it your valves are closed and you're good to go. If you can blow into it, your 180 out
I guess I just assu
I guess I just assumed he had it apart for something. The only time you should need to use a tool like this is if you aren't sure that the marks on your balancer are correct. If you know the marks are all good, you just rotate until the mark lines up with 0, use your blow into it method to see if it's 180 out or not, then stab the distributor with the rotor pointing at #1. Start it up and then fine tune timing from there.
82sbshortbed
Fuckemall!!
SE Texas
Doug
Thats why I love this site. So many different good ways to do something. Never thought about the tissue or hose trick. Good ones. Keep them coming.
metal tech
Choctaw OK
Al
84 & 85
K10 x2
305 x2
https://www.summitracing.com/parts/sng-33650
Mr Gasket or Moroso also make a whistle style. I tried to use the rod version shown in first post, no luck as the dome/valve reliefs on the piston bound up the rod. There is info that recommends the rod style for engines that have the spark plug in a vertical relation to the piston.
zapattack
