What size inverter?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Looking at power inverters. Mostly wanting one to be able to charge power tool batteries while away from home. About what size inverter would I need to run the chargers? I’d be charging 20, 24 and 40 volt batteries if that makes any difference.
Camar068
Kentucky
10 yrs Air Force
take all the chargers you want to run and add up the wattage written on charger or power brick. If they don't have wattage listed, Multiply 120 volts by the amperage to get the wattage for each.
After that, take your total and get one that is at least 10-20% higher than that.
Camar068
Kentucky
10 yrs Air Force
Also, you can go smaller, just don't charge them all at the same time.
bigcountry78
James
K10 Custom Deluxe
Easy enough. Thank you sir.
84c10454
