What is an goodwrench targetmaster 350?
Dawn dishwashing detergent is designed to cut grease, and it works well for just about any grease on any engine. As long as you don’t get it into the engine through the carb or valve cover holes, it will rinse off without causing any damage to anything. It works much better if you use a light bristle brush or a small dish sponge (the thin blue ones) to rub the heavy grime areas.
74Blaze
Nashville, IN
Gerald
K5/Blazer
Don't use Fast Orange to clean spark plug wires. It works great until the next rainy day when arcing causes massive missing and back-firing.
Statewurker
