SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Thanks for tagging me. That's about where I'm at. What plugs are you running if you don't mind me asking?Shades of @SirRobyn0 here. Changed # 8 with a good used plug I had as I thought I was feeling a slight miss at idle. Plug had like a white glaze on the electrode arm that appeared to have reduced the gap by half. Put the feeler gauge to it and off came the glaze.
Fired her up, still a bit of a miss, so# 6 gets the treatment. Same glaze.
Not a perfect idle, but for a 122K oil burning SOB good enuff.
So as an update, and also for those that haven't seen my thread on it, I discovered my sudden inability to keep #7 from fouling in less than 100 miles was due to the anti-ash additives in the diesel oil I'd started running. Going back to conventional gas oil I've now got several hundred miles on #7 and I've looked at the plug a few times, it has that gloss black oil burning coating on the insulator but is no longer getting impacted with wet oil deposits in less than 100 miles. So I consider that a win. I've even towed my trailer without getting a severe rough idle.
Is my idle perfect, no but it's back to where it was before these shenanigans and I'm quite happy about that. Like you for an engine with a lot of miles on it, and using some oil I'm perfectly happy.
I asked about plugs because I've currently got a full set of NGK UR4's roughly the heat range off ACDelco 44 or 45's depending on the cross reference sheet I look at. Previously I was running ACDelco CR43TS plugs, as it was what was in the truck when I bought it. Not sure if I'll go back to the CR43TS in the future or stick with the hotter plugs, but either way I'll probably go back to ACDelco's I'm running the NGK's because that's what was in stock at the parts store when I needed them on short notice.
