80BrownK10
Greenwood, SC
Nate
Got the wrong atf out and the new in. I Googled how much atf for a th350 and it said 4 qts. Ok with the 2qt deeper pan I put in 6qts. Drove it around the block. Ran fine shfted good. Park it in the street idling and checked it and nothing on the dipstick. Says check it hot, so should I drive it more then check it to get it hot? Of wtf? Lol
NO!!!! Don't drive it off the stick. You are suppose to check it hot on level ground in park. BUT you should still see it on the stick even cold and off. It will be higher on e warm so it should usually be just below the minimum line when cold and running, cold and off it may be a tad higher?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Hey guys, i got my 8.5" rebuilt!
Yukon Duragrip Posi ordered last night.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Went to start ol brown and got no lights, no buzzer and not a click to be found. Crap. :(
Helped my buddy wit his GJ. New water pump, new belts, my old Qjet, my old plug wires, new plugs, new rad/hoses, new heater core. She runs a lot better now but the heater hoses started to leak and also the plug in the new T-stat
Sent from my iPhone using Tapatalk Pro
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Started up the '80 today. Drove it around the parking lot in 2nd gear for a bit. Stretchin the legs, workin the juices. Ready for the spring
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
I see a computer controlled qjet without the CCC wiring????
I noticed a little wobble from the rear of my Burb the last few days. It turned out, one of my rear tires was separated. It was bald anyway. Really bald. Being cheap and still not wanting to buy tires for a truck with an uncertain future as a 2 wheeler, I installed the 35's that I found in a ditch a few months ago.
Y'all can say what you want, I'm a cheap ass and I'm ok with that, lol.
45tt
Florida
MJ
GMC Sierra Grande K15
Replaced my thermostat. I had a new 160degree in it but put a new 180 back in to see if that was my problem with the temp gauge not working properly. Nope, didn’t fix the issue. I also changed out the belts with a new set of gates belts. Got rid of the cracked belts that were probably 15 years old.
CRM
Pasco, Washington
Casey
K2500
350 CI
I had a temp gauge reading off so I replaced the temp sensor with one I got off of Amazon. It then read hot. Got one from the local AC Delco store and it read perfectly.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Finally replaced the battery, was dated 7/12. It's nice to be able start it without having to leave it on the charger the night before. The burb is purring nicely for the first time in many months. Engine's still ******, but it's nice to be able to move it around the driveway so it's not dead weight getting in my way
Auburn, Washington
Looks like the perfect vehicle to disperse protesting looters or BLM rally’s! Mad max!
45tt
Florida
MJ
im going to have to track down an AC Delco sensor. I think that’s the culprit
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
This Trans fluid level is getting stupid! Friday i put in 6qts and then drove just around the block and checked it and wasn't even on the stick. Checked it today and it's way up on the stick. Just pulled it cold to check it. There's no cold mark just hot.
It's all the way to the hump now. Wtf?
Should I fire it up and drive around the block again then check it? I don't wanna **** **** up by having too much in there. Why something so easy becomes a pita. Lol
Found this too
Pretty sure my TC is full so I don't need to worry about that.
hoagster
California
K10, 1500
5.3l
I
Found this too
Had an issue were everything would work fine, on my 94 suburban 2500hd, 454cid 4l80e, get done moving stuff driving around shut her down and it would puke fluid. couldn't find out were. I finally found a mud dauber hornet had plugged the vent line. it has been working fine since I cleared the blockage.
Jimc21NC
