80BrownK10
Greenwood, SC
Nate
That was a FRAM filter.
I hear about this all the time and see people reposting pics like this but this is the first forum where I have ever seen the supposed exploded fram filter.
Many folks say the walmart e cage supertech filters do it cause of the plastic internal baffle, but I have never actually seen one or pics of an exploded one. Just a side note.
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
It was FRAMs XG series filter. Supposed to be their better filter.
hoagster
California
K10, 1500
5.3l
I didn't do it but new exhaust finally!
80BrownK10
Greenwood, SC
Nate
Yea even the fram haters say that's a decent filter.
This makes me worry about the (orange fram) one on my Highlander now. I don't normally use them and try to avoid them. Not really been afraid of them but there is better filters for the same or less money. I had these for running them on lawnmowers and my Toyotas use the same filters as the do, and I didn't have one for my Highlander so I used what I had.
That said I have use to use fram almost exclusively in the 90s and early 00s and put tens of thousands of miles on them. I liked the grippy.
TX87R10
Txr10
Replaced the seals and guide felts on the passenger door last night. Took a bit longer than expected because the old felt was rusted in to the channel on the frontside of the window. About an hour of scraping and wiping to get it clean again and install the new felt...
Then the motor that was already slow with 33 year old seals doesn't like to go up and down without assistance anymore. Time for a new window motor on the passenger side it seems...
Going to do the driver side tonight. Watched a video on the back seal. Ho boy that doesn't look fun. Time to order some new window working tools from Amazon.
78C10BigTen
pennsylvannia
C10 BIG TEN
I have to say ive never had issue with fram, i always use them. I actually just bought one for my s10 oil change today.
John Nes
Atlanta
R10, Sierra, C20
5.7 350tbi , 5.7 350, 5.7 350
Having done this a few times, best advice I can offer is using some glass cleaner spray-foam to help lubricate the channel runs to accept the felts. By rear seal, is that the rear channel run for the glass ? If so, it’s way easier if you remove the guides lower bolt and loosen the guides top bolt on the jamb.
TX87R10
Txr10
I saw a video recommend spray detailer and it seemed to work pretty good so far. On the rear I meant the rear window seals, I bought a kit that had both doors and windows and didn't realize it involved removing the rear window as well >.<
John Nes
Atlanta
R10, Sierra, C20
Ah gotcha. I too need to swap out the motor in mine and have been putting it off cause it’s such a pain dealing with all that
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I'm partially color blind and can see colors but didn't find out till a few years ago after years of marriage and my wife saying I had messed up color vision. I see colors but shades sometimes are different and I see more colors as a different colors, like teals that are combos of two colors like blue and green.
I didn’t know I was “colorblind” until they gave me an Ishihara dot test at MEPs. Didn’t see many numbers pop out. Weird thing is I can distinguish colors accurately in real world applications. I have a buddy I work with that’s always screwing up color coded wiring. He’s seriously deficient. I have to come in and fix his wiring faux pas regularly.
Poppy 87
Bloomingdale GA
R10 Silverado
All the talk of being color blind, weren't you guys tested? I'm 55 and we had testing for that in elementary school, guess that was early 1970's. I grew up in Minnesota
Sent from my XT1254 using Tapatalk
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Maybe I missed that day. I stayed home for foaling, calving or just random fishing trips more often than some.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
Changed the oil and filter used a Wix XP filter and Schaeffer's OTR Plus 10W-30.
I am currently replacing the vacuum advance in the distributor and going to set the timing and see if power and economy with improve.
jake wells
Can i be me?
jake
custom deluxe 10
Yeah peeps for that reason i don't run fram garbage on anything i will tell you good filters to run in a SBC.
Wix
Baldwin
Hastings
Doug Hampton
