SDJunkMan
Black Hills of South Dakota
Jeff
If it has electronic speedometer, I am interested
Sent from my XT1254 using Tapatalk
I assume an electronic speedometer doesn't have a cable going to it? (I've never seen one). I'll check when I get it home and let you know.
Poppy 87
Bloomingdale GA
R10 Silverado
Correct, no cable
Camar068
10 yrs Air Force
I put that in around 2 months after I got the truck, it was a (appearing never used) Sony xr-2100, I something isn't right in the mechanism as it would try to eat tapes, but not a big deal since I have my Bluetooth setup on it so I stream from my phone most of the time, interestingly I found another Sony head unit, a xr-2600 (with line out), which is going to be put in my 79, also in very nice shape.
Sent from my Moto Z (2) using Tapatalk
Now-a-days I like a USB input on the back. I've got a 64GB usb drive with music on it. Local (hillbilly) radio stations piss me off. One will play journey (something over played in my mind) so I switch to the other good station. Bet ur bottom dollar the next song is by Journey on that station.
Little rant here.....sorry but who wants to listen to a slow ass pink floyd, bob segar, dust in the wind.....slow moody ****.......On their way to work when their trying to wake up!!!! Play something a bit faster to help me wake up! Sorry had to vent lol
78C10BigTen
pennsylvannia
C10 BIG TEN
Since I don't smoke I decided to swap the ashtray out for something more usable to me, a dual USB charger. The way I did it required no modification to the ash tray door so i can revert it back if need be.
Also got my auxiliary fuse block installed and wired up, Powered from the junction block on the firewall and has a 70A relay to provide it power using the original fuse blocks ign acc to power the relay. I like this as it has leds on each circuit that light up if the fuse goes out. Also it has a ground buss bar which makes finding a good ground easy (grounded to the parking brake ground connection). Wish I would have done this 3 years ago.
My 15x8 Wheel vintiques series 62s arrived and I hit them with some white rustoleum enamel, and off to the tire shop.
Got some 31/10.5/15 BFG K02's put on it and shined up the dog dishes that I stole from my 79.
Looks good!!
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Well, I needed to get my brake lights working. A little video call on messenger to @Vbb199 and him telling me it was the switch on the pedel with orange and white wires going to it was the brake switch. I went and got a new one installed and cleaned up wire connections and now they work.
Thanks to Vince I saved a lot of time fixing them. Thanks bud!
Now I move on to fix plate lights. Getting closer to getting my safety inspection. Lol
Poppy 87
Bloomingdale GA
R10 Silverado
Safety inspection? In Texas? Damn, I figured their only inspection would be that you are properly locked and loaded! Good luck
ajd89
Central Michigan
andrew
New trans mount. Wonder how many miles are on this one. Wow!
82sbshortbed
Fuckemall!!
SE Texas
Doug
So I tackled the plate lights next. Had to do a little modification to them but, came out pretty good.
Old one with new light after a little dremel cutting.
Back of it
Bent the tabs to hold it in there snug
Cut the ends off the old one so I could secure it to bumper.
Poppy 87
Bloomingdale GA
R10 Silverado
Cleaned up wiring and now they are working.
Not too bad. Should pass no problem.
Interesting, my 87 has factory step bumper but only 1 license plate marker light
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Anytime!!
78C10BigTen
pennsylvannia
C10 BIG TEN
Vince is good for help!
Doug Hampton
