bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
I put a caliper hardware kit in because my 40 year old original was tired. Also tightened up a loose shock mount I found in the rear and put a new bulb in one of my driving lights that was burnt out. Locked up the rear tires today when someone stopped short in front of me, had to go home and change my shorts on that one lol.
Wumbo
Illinois
Rob
Pocket ported and gasket matched a pair of 049 oval port heads. Dropped them off for guides and valve job. Comp xtreme 4x4 cam X4 262H on the bench ready for installation.
Preston
Mechanicsville VA
Preston
Installed headers on my 1985 Silverado, thought I was going to be able to bolt up a set of header mufflers and be done, wrong the transmission crossmember is in the way. I just ordered header extensions and 2 Mega flow Rumble mufflers, waiting on delivery. In the process of this install I rerouted some wires, installed wire looms on spark plug wires
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Mine ran into the shifter linkage. It’s always something!
idahovette
Weiser Idaho
Perry
K20-K10
Got 2.19's and 1.88's now or are you going to?
Wumbo
Illinois
Rob
No, 2.06 and 1.72. Will still be a major improvement over the stock cam and peanut port heads though.
Doc_Ellis
Nashua, NH
Keith
Sierra 1500 shortbed
Buddy of mine who restores BMX bikes taught me this trick for cleaning up rust pitted chrome a while back. Crumpled up aluminum foil and cooking oil. I felt like doing a quick five minute fix so...
To be fair, I was planning on doing real work today, turning this pile of crap into an exhaust system (side exit).
But I decided I wanted to incorporate a v-band clamp for future ease of service (and baller status, let’s be honest) so I’ll have that next week and then can finish this up.
And I replaced the broken spring for the hood safety catch. Meh, another five minute fix but sometimes the little things are the most satisfying.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
I used 4/0 steel wool on mine, worked great.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
You just scrub it with crumpled up foil and oil?
78C10BigTen
pennsylvannia
C10 BIG TEN
Ok so how do you do it??
fmxr47
US
Justin
Bolted my bed on today
Doc_Ellis
Nashua, NH
Keith
Yup just ball it up, dip it in the oil and go over the rusty areas. Doesn’t even take a lot of effort. My friend swears by olive oil, but I think it’s just cause he’s fancy like that.
I used canola oil because that’s what we had in the house but I know I’ve used other kinds in the past and had good results.
TravisB
Travis
I wonder what is actually happening here... Does the foil stick to the rust to give the appearance that it's all chrome again or is the rust actually removed by the foil? What does the oil do? So weird... but it looks like it works to me so no argument just wondering how.
Vintage_Phinds
