Timbo
Portland Oregon
Tim
C10 swb
Built a sbc 350,made some kick panels,patchand body work waiting for painter now
350 w/203
Must be nice to have a lot of spare change.
fmxr47
US
Justin
Removed a bunch of unnecessary junk from the frame this evening and burned a hole in my frame [emoji51] something else to weld up [emoji1743]‍[emoji3603][emoji1751]‍[emoji3603]
Carb'ed Vortec 350
Whoops!
Carb'ed Vortec 350
Like that color.
73c20jim
Tombstone, AZ
Took the OEM front grille out of my 73 C10 parts truck. Looks very usable. I hate the billet grille in my 73 C20. Can't open the damn hood easily.
Got a Autometer Pro-Comp Memory tach for $20 from the junk yard. Beat up, but it works I scored. The memory erase button is broke but I don't plan on using it. Just want a simple tach.
The MSD 6T came with it, but I have no use for it. HEI is good enough for me.
:patriot::patriot:
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
New rear leafs, shackles, rear front hanger on D side, all new bolts, and monroe mag shocks all around painted hammered copper.
austin234
California
austin
5.7L
first post! it was slow at work yesterday so i intalled my flip kit and spindles w/ springs in the front. looks pretty decent. then did some burnouts to celebrate. now to figure out why 3 of the 4 wheels are locked up after pumping the brakes, thinking proportioning valve but im not gonna buy a new one since itll be swapped out when going disc/disc. its only gonna move like 3 miles in between now and then and it has enough juice to roll the tires still
78C10BigTen
pennsylvannia
C10 BIG TEN
Started her up for the first time in weeks... last time it ran i put stabil in it to reduce the water and ethanol crap, seems to have helped. Alot less condensation under there this time. And yes i know she aint pretty.
ajd89
Central Michigan
andrew
Took my enigne down to my grandpas and we got the 4 exhust manifold bolts out 2 with heat and vise grips, 2 had to drill and tap but it wasnt to bad! Need to pick up new seals, timing chain, oil pump and paint now. Then wait for it to warm up to pull the old eninge out!
Big Chip
Michigan
Kevin
C35
Finally Got my box painted... yippie
Send some pictures after you get the paper peeled off. I’d like to see that fender painted something other than the middle body color.
Jonny79
