Boonie
El Dorado, KS
Brent
i rerouted my fuel line, and replaced the plugs and wires today. routed and loomed the wires a lot nicer than they were before. got rid of the annoying little miss it had. also got the interior lights to work with the door jamb switches, replaced the washer pump so it works again. not sure why im doing all this since the plan is to tear it apart again, replace the wiring completely, and do a partial frame off on it, upgrading things for reliability and drivability as I go.
Took my boys for a ride today :) they had a blast
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
well took the truck for an 1hr drive to see if everything is up to snuff after the ecmb incident .It ran great so i feel confident taking it on long trips again.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
I made some progress installing a limited slip in my front axle.
Will wrap it up tomorrow when I am fresh and won't be working in the hot sun.
It's nice now, the axle shaft u-joints aren't hitting the lower ball joint stud like they were.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
Got a new tank support, installed new gas tank.started it up spitting gas. found out had a leaking hose.dropped the tank again, new hose, new clamp, now its all good
firebane
Calgary, AB
Curtis
Finally got the passenger side head off the truck. Not its cleanup time of the head surface and block to get rid of so much old grease and dirt.
You would honestly think that the truck had a MASSIVE oil leak its entire life ugh.
had a rough day truck broke down on the main street. the ecmb fuse kept blowin . so I had to get towed home $120.. for 3 miles . so I got home and googled the problem . they said to follow the orange wire which goes to fuel pump relay and to the oil pressure switch. turns out the 2of the wires going to the oil pressure switch fused together . once I separated them everything was fine , so if anyone ever runs into this problem just look for the orange wire and see if its casing is messed up and touching something. :)
Sunuva Bitch !!! $120 for 3 miles?
Oh yeah, you're in FL. And of course they consider 1 ton dually cc a medium duty. At our standard rate, it would have been $65 hook 5 miles free. If it REQUIRED roll back an additional $30, but unless it was 4x4 rb not required so $65. If we wanted to do state LEO (Law Enforcement Officer) rate, it would have been $81.25 Hook, $3.75 a mile.
To hell with that dropping the tank ****. I find it easier to move the bed back in most cases. This way you can for sure get to the lines and know you didn't kink them putting the tank back up.
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
Here we do it by the hour. We would have charged $85 for that unless it was a LEO call. Then it can go as high as $178. We don't charge extra for rollbacks though.
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
I'll have to try that next time. Hopefully there wont be a next time.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
it was just an all around bad day I have 3 friends with tow trucks , 1 was broken the other was on a tow 50 miles away and the third was not driving the flatbed . else all I wld have paid was $40.00 . And the fix was so simple but when it happened I had no clue what it was till I googled it when I got home, cost me $5.00 to fix well add the tow $125.00 lol
Konas new ride
Alberta
Gerald
I was wondering how it was possible my headlights were that bad.. Well.. I adjusted the passenger side one down from above the tree tops and the drivers side one that was aiming at the right side of the road.. Holy sheet.. I can see now...
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Is that as simple as removing the bolts and sliding it back? Or more to it?
Sent from my SCH-I605 using Tapatalk
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
put a new battery in. its great to turn the key and it starts up.
MadOgre
NA
NA
NA
NA
NA
Ya don't forget the filler knecks attached to your tanks are also attached to your box!
jlyon1006
