VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I left it on just dont have it bolted to the back. Mines off a 92 burb 2500 454 with serp ..you can get a 100 105 120 amp maybe 140. My trucks a 454 wuth v belts 12 si 70 amp I might look at rotating the housing to get bracket lined up if it can . Not sure on 350 the bolt holes need to be 12-6 oclock on alt
Groovy, I saw you started a thread on this, I'll keep watch on it. Thanks Bro.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
I put a cs130 alt on today got the conversion plug from orilys $20 then switched pullys to the vbelt bolted right on. The rear stud is lower on the cs130 kinda snug to the head but clears. Pushing 120amps now not 70 lights are brighter feels like it runs better. Less drop from the fans turning on. Working great so far.....
I would like to do the alternator mod also, where did you get the plug in adapter for the wire, and is there a part # ??? thanks in advance
MadOgre
NA
NA
NA
NA
NA
when you go with the large alternator they usually tend to last longer. I guess because they don't have to work as hard ?
350runner
tx
Ceasar
X2 I spent a total of $50 including the pullies. Money well spent
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
put the front wheels on today going to do the rear tomorrow.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
Did an oil change.
Installed new front air dam.
Tried to install new air intake cold tube. But it is way too long. Picked the one from LMC that is supposed to be for my year truck. :shrug:
Bought a new stereo and a marine box to install it in, like 1Low4X4 did.
Konas new ride
Alberta
Gerald
Rear drive shaft is in.. It's much better (couldn't get over 45 mph with out a bad vibration). They had to re tube it for me. Once i get the fire wood out of it i might actually pull the shaft and change out the u joints. But i need to unload my load of fire wood..
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
well truck runs really good and looks good just need a paint job and get the front bumper with the lights.
350runner
tx
Ceasar
Nice man!
Looks evil lol
silverscottsk10
trafalgar indiana
mike
Header has a break between the flange and the header tube :/
Gotta find me a welder soon
firebane
Calgary, AB
Curtis
Sometimes things just work out in the end. I lost a bit of sidewall as the originals were 85 not 75 but I went from 235 to 245 so I gained the width.
Even being 16s these tires look TINY lol.
jlyon1006
