anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
Why did you mount headermount hornys separate from the headers?
because it will hit transmission crossmember if u look at the header extension, it has a S curve to go above or below crossmember
1sic4x4
Az
Stan
k20
350ci
What I did!
Hey all, I was busy this morning put the repaired radiator back in K20 new hoses, thermostat, and belts, also worked on the dash, new fusses, lite bulbs in dash cluster , blew out and cleaned Cluster, & behind dash and pad and reinstalled all back in Truck:favorites25:
bluex
Spartanburg SC
C15
Put insurance back on it. One of my days off next week will hopefully be spent getting the property taxes paid an then a tag so I can legally drive it again! :D
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
started painting the newer front clip. got a fender and valance (under the grill) done. its flat black now. have to weld the emblem holes on the other fender now.
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Tightened up my tranny crossmember. For some reason it was loose?
Oh an took out my front driveshaft so i could replace a ujoint
smurph20
Brad
LMAO yhup you got me been hanging around Retro to much lol
Big difference between a tranny and a x-dresser. :rofl:
I know that, and I wasn't referring to you btw. It did say tranny crossdresser, so that's one who does both, is a tranny and does crossdress. I just figured smurph wore his tranny crossdresser out a bit. I've heard a little Preperation H will tighten things back up agian, so maybe that's what he did. Smeared some Prep H on his his tranny's bung hole and got things all tightened up again. :rofl: :laughing1: :happy175:
Jus kiddin, jus kiddin. Couldn't resist the ease of that one smurph.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Limped it home 11 miles in 2nd gear because it wouldn't go into 3rd/4th...Got within 1 mile of home, and it finally decided to drop into 3rd and 4th gear and was fine the last little bit.
Screw you 700R4! I'm getting a TH350 built and ripping this POS out.
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I just replaced my driver door regulater and motor and switch. Works like a champ now
If it's got the wussy 2.73 or 3.08 gears in it, yep for sure. Just go with a Th350C in it. You're losing or lost your 3-4 clutch pack.
chubble
Eastern, NC
Custom Deluxe K10
Removed my drip rails and wire brushed them and painted them black. Pulled my front marker lenses out to clean them up or grab some better ones from the scrap yard.
Hopefully his isn't like mine and has 2.56 gears. That sucks for any occasion.
Tdabney
