Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
I pulled that ugly trim off mine last year. Luckily it didn't have rust like that under there. I believe it was faded out...and maybe broken? I'm not sure. Does LMC not have it? I'll try to remember to find mine if I didn't tear it up and throw it away?
it isn't rust, but very small potions of the blue paint came off with the trim, revealing the a little bit of the previous color. I can almost live with that if i can get the glue off, worst case i don't find a new trim piece. LMC does not have it. I've checked, too many times to count
80BrownK10
Greenwood, SC
Nate
Let me see what mine...if I still have it looks like
JeffK10America
Easley sc
Jeff
Finally getting something done. Ordered 3 coils of SS fuel line (1/4, 5/16, 3/8) - as soon as that arrives I'll finish it. Got the new stainless brake lines into the frame and the crossover lines bent and in (my buddy had about 4ft of each size left). New tanks painted / Rhino-linered bottom halves and hung. As soon as I have the vent line run to the front, can put in the motor mounts. Its getting there....
Hell of a nice frame ye got there !
That took some time .
JeffK10America
Easley sc
Jeff
Just got my bed off , frame was covered in dirt , not rusty .. just degreased it , next brake lines maybe springs . Or bushings anyway . Shocks of course . Paint it up before I install everything
JeffK10America
Easley sc
Jeff
Powerhouse Ranch
3G Connoisseur
PA
Luke
'80, '86, '88
C25, K5, V15
Nothing like truck parts for my birthday, brother got me door panels and my other family members combined for the emblems. Not bad at all. . .
Changed the transfer case fluid, changed the oil + filter in the Jimmy, wanted to fill up the front diff but one of the bolt holes is stripped out. I'll have to tap that it appears. But i got the front wheels on (back put on last week) and bled the brakes for the first time through all of my new system, which i flushed. She can now roll down to my dad's shop to begin the wiring phase and finally get this thing manageable and see if the 350 will do.
FireTruck1984
Michigan
Ted
1984 and 1984
I put new signal/parking light housings on it, and added some factory style wheel arch moldings from LMC. I think they give it a more "finished" look....
Quite a difference between the old lights and the new....
Love your Wheel and Tire setup ! Looks great
FireTruck1984
Michigan
Ted
1984 and 1984
Yes, trim always finishes the truck. Looks great! Original ‘85 grille and lights would take it to the next level.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Got the rotating assembly done on my c10's th400... just waiting on boost valve to put the pump on.
Once its all done, that should be a hard hitting mother ******. My best work thus far
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
How far to press it on? All the way, my friend, all the way. If not, the truck will press it the rest of the way and you'll destroy the bearings.
No shims in that collection of parts? Have you measured pinion depth?
That's good to hear. I thought maybe I forgot a shim. I can go a little more till it touches the back of the pinion gear. No haven't measured pinion depth. Sometimes I get ahead of myself. Lol
It was raining here so no more done to it today.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
The bearing MUST be seated. I'm concerned that there's no shims or depth measurement involved. What's up with the previous pinion? No shims?
John Nes
Atlanta
R10, Sierra, C20
5.7 350tbi , 5.7 350, 5.7 350
Wiped the hood with some of The Sweet Patina’d patina preserver and drove the **** outta the thing
82sbshortbed
Fuckemall!!
SE Texas
Doug
I measured 6.1 from the end of the shaft to the bearing on both but, new one wasn't all the way down. That's why I thought I may have forgotten a shim.
The old one
New
I think it's the bottom left shim I forgot to put on first.
So I think I need to get the bearing off and put shim on first then seat bearing again against the shim. That's what I mean by getting ahead of myself. I'd rather have to buy a new bearing than put it in and destroy more than that. I have a good feeling that's what I'll have to do.
Quick performance gave me a number to call. I'll ask them tomorrow to make sure. Shouldn't have put the bearing on until I was sure about it.
seanhatesregister
