Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
It said bonds to skin instantly so it must be NO joke! Lol only took a very light coat and about 45 seconds of pressure on it and it was holdin... gorilla glue fell off instantly. Never been one for jb weld but i think it maybe worth it...
JB Weld is good for a lot of applications. Some particular applications may or may not work well, or could be the prep. It was originated in my home town. Sulphur Springs, Texas.
https://en.wikipedia.org/wiki/J-B_Weld
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Did you use the JB Weld Superweld?
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
After a considerable amount of cold beer finally finished the A/C box delete this afternoon, here is the end result for now. Time to throw the steaks on the grill and refill the beer cooler! Life is GOOD!:cheers:
I have to ask. All you guys that are lucky enough to have ac, WHY is it so common to remove it?! I’m over here wanting ac and everyone else is trying to get rid of it.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I took it off when i replaced my motor and it just never went back on due to yet another motor swap
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
I never keep it on anything I own. I have no real reason other than I never use it.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
Thanks, I'll remember that when I need to reinstall my mirror.
Also, another thing that Sulphur Springs is known for, not as big as JB Weld, the McKay Music Co. is where Don Henley of The Eagles bought his first drum set. They have been in the same location I know of since 1960, maybe longer.
Just thought I would throw that out.
SDJunkMan
Black Hills of South Dakota
Jeff
Up here I only use it for a short time each year, so when it craps out I just get rid of it instead of fixing it. It's a lot easier working on the engine without that big a/c unit in the way.
73c20jim
Tombstone, AZ
Tach and MPH still not working. Drove 75 miles to pick up 3500 pounds of RR ties. And returned. Used phone for speedo.
38 psi oil
sometimes speeds up to 68 (empty)
fuel gauge needs dip switch reset. Shows 1/2 but seems to be accurate otherwise.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
I removed all other a/c components when I rebuilt the engine and really rarely used it anyway. I prefer to listen to the rumble of the engine and my loud ass exhaust! Now with that big ass ugly box out of the way it will be much easier to tinker around in the engine compartment.:cheers:
Kim Burke
Northern IN
Kim
C1500
Has to be getting torqued by the brakes. Caliper, likely, or the upper control arm (bushings/ alignment shims), less likely, or upper shock stud(s)? Probably something simple.
I had a rattle on the right front. I found out the insert trim on the door was ready to fall off.
Big Chip
Michigan
Kevin
C35
That stuff will all be gone through when I finally pull the trigger on the lowering kit. No point taking it apart twice.
Sharon
