smoothandlow84
I'd rather be draggin' frame
- Jan 4, 2015
- Arizona
- Steve
- 1984 Frame...87 motor and 700r trans
- 1500 r10 pavement scraper
- 350 TBI
Another thing to consider, is a 3" spindle will have the control arm hanging below 15" rims up front. This is neither safe, nor legal. A 2.5" spindle would be better, though I suspect still hang too low.
When my 15" BFG's are done, I'm going 17".
X2 with the 3" spindle. The p.o. did a hack job when lowering the front end of my square and still using 15" rally wheels. If you opt to use a 3" drop spindle, larger diameter wheels are necessary and safer than hacking the lower control arms. You can notch the lower a arms, but be sure to plate it so that its is reinforced. The easiest way of course is to use a 18" or larger wheel setup.
