What could this random tube attached to the exhaust be?
Chris64
San Diego
Surely someone can explain this mystery tube to me. It's hose clamped to the exhaust for some reason. It's not drilled out or anything if you look down the tube. It's just clamped to it and barely hanging on. Chesterton's-random-exhaust-tube. It's better to figure out why it's there before removing :)
Excuse the rust. I'm working on it.
Redfish
Prairieville, LA
Andrew
V1500
It almost looks like a poorly fabricated heat riser. The truck originally had a heat riser that ran from the exhaust manifold straight up to the neck of the air intake duct of the air cleaner. Maybe the Previous Owner was trying to recreate that?
Auburn, Washington
99% sure someone fabbed up a connection for a carburetor heat riser for an OE air cleaner like was present on original OE exhaust manifolds.
Chris64
San Diego
What function did this serve? Should I complete this?
Radiohead
That guy on the Columbia
MCMLXXIX
C-20 Silverado Camper Special
On the stock air cleaner housing there is a diverter valve that has some of that metallic flex tubing attached that goes onto that piece of pipe. When it's cold, vacuum is applied to position that valve, allowing heated air to go into the carb and when operating temp is reached, that valve will retract to allow "cold" air to the carb.
I could have the vacuum application backwards, but that's how it works and why.
Being in San Diego, you may never need it, but go anywhere cooler, it will help the cold driveability. I'd put it back to operational.
RaisedK5
Leland
Blazer
Similar to this.
77Matt
TO, CA
C15
5.7L 350 V8
Does exhaust actually come out of that pipe? The heat rise isn’t actually connected to the exhaust but sits up against it so hot air rises.
emoze
near Sacramento
lary
in CA, pre-76 is exempt from smog inspections; just remove it & enjoy the truck ... (unfortunately my 84 is not exempt)
hdchevy
Florida
HD
It is designed to channel hot air from the exhaust manifold to a value in the factory air cleaner. No exhaust just hot air.
59840Surfer
Montana
Joe
Kinda like the old VW Bug heaters that took heat from around the exhaust manifolds and routed it into the cabin. Nobody died of whom I am aware of this system although it seems kinda iffy.
I liked the Corvairs better --- the early ones had actual gasoline-fired furnaces in the front cargo space that could heat you to incendiary values without the engine running. I melted the soles off my Uggs once in my 1963 Corvair --- BT- DT.
The early bugs were the fun ones,before they went fresh air,.( that's the system that blew air through skins around the exhaust manifolds) the previous ones blew the air that cooled the engine into the car,oil leaks,head gasket leaks,and all.
thatgermanguy
