What are these holes in my intake?
Ypsik10
Ypsilanti mi
Chad
Different from my stock 305 intake large front driver side hole? The two holes drivers side next to carb need to be plugged? Same with the one right behind intake in the block..
vkh
Western Montana
Var
C2500
The hole next to the thermostat spot is just an alternative location for you temp sensor, not sure about small blocks but early big blocks used a manifold sensor and didn't have a spot in the heads for one. It's handy if you want to use a fan controller or some self learning EFI without messing with your gauge sensor. Otherwise just get an NPT pipe plug. Now the two holes next to the carb are for the AC mounting bracket, I imagine this is specific to some years but regardless you don't need to worry about plugging them. I believe the back hole is a provision for an oil pressure sending unit, if you are going to mount your sensor somewhere else plug it (also NPT). Now I haven't done too much with sbcs (all my experience is bbc) so take what i say with a grain of salt, someone else will probably chime in to confirm or deny.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I dont have an edlebrock intake, but I can say that on my stock manifold the oil pressure line is at the very back of the manifold near the coil/distributor.
1973c10
Don
The one right behind intake in the block is for your oil pressure line for mechanical gauge
or for oil pressure sending unit for electric oil pressure gauge
passenger side - port to heater core if used
driver side - temp sending unit, if you need it
the one right behind the crab is a vacuum port to brakes if you need it
Ypsik10
Ypsilanti mi
Chad
cool thanks everyone!
Camar068
10 yrs Air Force
as usual, learn something new every day. Never see a brake booster hooked up to anything but the carb. Thx
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I guess that spot would also work perfect for a vacuum gauge then, huh?
Camar068
10 yrs Air Force
lol never seen an old school vacuum sensor or guage.....I reckon so. Swear they should have made it an option for a "gear heads" package to include vacuum, fuel pressure, trans temp and others I'm missing. It would have carried on if they'd offered the damn thing as a package.
74 Shortbed
That port was used mainly for the modulator on the tranny, then used for smog garbage and whatever else that can use straight manifold vacuum, so it can be used for a vacuum gauge for sure, just need to add a fitting.
74 Shortbed
Never seen one hooked up there either, but it surely could though.. :D
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Was thinking it'd be a cool quick spot to use to check for vacuum without disassembling anything else.
74 Shortbed
Yep it would, that port can be used for anything that needs manifold vacuum, just make a tree, lol..
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Keep stacking 3-way and 4-ways til it pops outta the hood? Hahaha
highdesertrange
kalifornia
mike
k30
the oil pressure port on the back of the engine is on the block not the intake manifold. highdesertranger
cahillasher76
