What A 500 + HP Peanut Port 454 Looks Like
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
Mark Jones
Mark
This smooth idle engine went on to run 10.30s @ 3720 pounds in less than sea level conditions. Never under estimate a peanut port head (236) or most Chevrolet production parts, as they can deliver.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
So it appears like it ran with no alt, ps, accessories and an electric water pump,
And you ran pop top pistons to squish the chamber super tight (piston pic is blurry)
How much timing did it allow at peak power
Mark Jones
Mark
35 degrees total is where it was raced at.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Always good to see you Mark. What cc are the pistons, 20? Also what did your static compression ratio come out at? Are you running a Moroso vacuum system?
drewscleancars
