- Jul 30, 2010
- Midland, Tx
- Tyler
- 1500HD Quadrasteer
it must have good fuel pressure since it's getting so much fuel
It might have to much pressure
I knew it was electrical!!! I think.ok it needs a distributer,we got it figured out
That was it huh? Runs fine now?got it going with a distributor and a rotor
usually too much fuel in a tbi motor is coolant temp sensor, you should always check it first, it'll make em run rich when they go bad and they are only like $12.
Yep.That was it huh? Runs fine now?
Replaced CTS a long time agousually too much fuel in a tbi motor is coolant temp sensor, you should always check it first, it'll make em run rich when they go bad and they are only like $12.
