84prspctr
- Apr 5, 2023
- ca
- ben
- k10
I have a sbc 350 with no heater and no thermostat. I just did a coolant flush and new lower hose and found out there’s no thermostat in there. I had my hand over the bottom bung on the rad and put the hose in the rad to flush it and water started coming out of the water pump where the lower hose hooks up, so there isn’t a thermostat I guess. Anyway my water pump just started leaking out of the weep hole after I just changed the coolant so I need to put a new one on. I want to put in a 180 thermostat too. I am not familiar with sbc engines, I know with mopars they have a bypass hose on the water pump for when the thermostat is closed. My truck doesn’t have any heater hoses, just the pump and rad hoses. Is the bypass internal or something on these pumps when the t stat is closed? And what would normally be in this plug on the top of the pump? Thanks
