Okay, I dont have an rpm gauge because the truck came stock with just the big fuel gauge, duly noted on the power or mpg trade off, i feel like I want more power because i do know for sure that the late 70s has the emissions tech which makes them low horsepower and kinda sucky. is there a way I can find the RPMs without a gauge and more accurate than listening to the engine? Also dumb question but what exactly does the rear gear ratio do? and how to change it when I need to. Thanks!
Let's get the terminology correct so we understand each other.. It's not "rpm gauge", it's tachometer.. Now to answer your RPM question.. I've been building engines since the late '50s when I was about your age.. I raced cars and built race engines for some of those years.. I can listen to an engine and make an educated guess as to the RPMs but no way is that a reliable method..
Your engine building project, in the end will cost you somewhere north of $3,000.. And that's only the actual cost of the engine.. Savings can be had by the use of used/reconditioned parts, and /or existing parts. You'll need many tools, both special and "contemporary". One of those tools is definitely a tachometer.. You can get a small "hand-held" tachometer for test and monitoring, and/or you can get a nice big one to mount near the driver's position inside your truck for constant monitoring..
I'm saying the following to enlighten you and is not in any way to belittle or insult you, absolutely not.. I was once 16 years old and, much like you, I had a very low level of "automobile knowledge".. The members and myself are here to help you in any way we can.. I suggest you spend a lot of time searching the internet for articles that explain the many faucets of automotive repair and service.. A good starting point is a Factory Service Manual. You'll find answers as to how something works. There are sites that offer free downloading of these manuals..
The rear end ratio is important in that it changes the driveshaft spinning rate (RPM) to a lower rate on the rear axles, a sort of torque divider or multiplier. Typically, with the transmission in high gear the driveshaft spins at engine speed (RPM).. The higher the rear ratio (lower numbers), the axles speed is nearer to the driveshaft speed.. Conversely, the lower the ratio (higher numbers), the slower the axles spin in relation to the driveshaft.
