Vintage Air Gen V (5) or replace existing compressor, etc., for 1987 R20 Suburban?
gmbellew
Kansas city
glen
suburban 1500
Thanks. I bought a new one, so plan on replacing it.
make sure air blows through it before you install it. reason I stress that is I didn't do that one time and then had to tear it down and replace it again.....new parts sometimes are also bad.
beady
Tidewater/Northern Neck VA
Mine
R20
Thanks, good thought.
beady
Mine
R20
Any thoughts on how to repair this heater box? Was held on with two short lag bolts at the bottom from inside the truck.
And the plastic tab that holds the spring/cable is broken off.
Anyone epoxy repaired, or maybe there are replacement tabs/reinforcements you can buy?
I ended up using an Adele style clamp from the hardware store. Still not finished with everything, so not sure how it’ll work long term. I have the heater box mostly back in and the cable seems to function correctly.
ram84
