Vent window handle replacement
WFarm
Central Virginia
K5 Blazer
Decided to replace my wobbly and pitted vent window handles today with a kit ordered from Classic Industries. What a difference! Tight and shiny just like new. I do not hear real good but I can notice less air noise while driving now.
The kit included extra parts, but kept track as I removed the old ones so I wouldn’t get tripped up. The old ones didn’t have a plastic seal on the inside but I added one and all is well. Old parts on right, new ones on the left in picture.
Scott91370
Burleson, Tx
Scott
Sierra1500
Same sets that LMC sells. I just put mine together and it wasn't too difficult. I did notice that if you try to open the latch without clicking the unlock switch they will spin a little in the glass. Not enough to be able to open though.
They are tight which is nice! The problem I have right now is the silver striker plate on both driver and passeger sides came off and nobody makes a repop. I'm probably going to have to find a small rivet to put them back on.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
Those plastic washers break fairly easily and are not a Stand alone part you can get the last time we tried. Finally put Vintage Air in and told E to not use the vent windows much as that caused the black plastic washers to break.
84GMCSierra
Central Arizona
C2500
My problem is on my 84, is I can't get the pin that holds the handle on, out. I tried lightly tapping it with a center punch, but no luck. I don't want to break the glass, so what is the secret? Would a spray lube possibly help(PB Blaster, WD-40)?
WFarm
Central Virginia
K5 Blazer
I gave mine a shot of PB Blaster and let it set overnight. Then used a punch to drive them out. To install the new pins I ground a chamfer on one end to help get them started.
I used a large pair of channel locks with softeners to protect the finish to install the new pins. The channel locks drive them in almost all the way, then finish driving them with your punch.
Randy and Easton
Randy
C-10 LWB
We use a small rivet or punch to drive it out as well. Doing it again today since we replaced the drivers vent the was shattered after ice storm and too much pulling by a 16 year old …,,,
Khayward
North Idaho
Kevin
Suburban SLE
I recently did this too and had to drill the roll pin out and even then it was a fight to extract everything.
Mine were so loose, I could turn them from the outside and reach through to the unlock button in the event I locked my keys in my truck (did it a couple times lol). Replaced my locks right before I went to Dino's Git Down last year. What did I do on the way back? In the middle of a blizzard? In the parking lot of a restaurant that was closing? Locked my keys in the truck... :banghead: :lol:
84GMCSierra
Central Arizona
C2500
oops
Hottshot0069
Schertz, Texas
Doug
Any recommendations as to where to purchase a good set of these? One that will last more than 18 months. I have already replaced these handles twice now. The rubber gasket keeps getting dry rotted and then starts coming out then the handle just moves around and let air come in through the vent. I end up having to shove paper be hind it like my dad did back in the day.
blue900
Blackfoot Idaho
Ron
GMC 1500 Suburban SLE
I am looking at ordering Window replacement latch kits from Precision they are not cheap I hope they will last another 35years .
I just ordered the rubber parts to do both front doors and windows from GMCpauls
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
I got a set from AMD and they went in fine even though I had to figure out where they actually set at rest and open after installing. Just a slight adjustment. Once they were where they were supposed to they work smooth like they should.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Similar methods of installing here with the center punch for the pin until I could grasp it with pliers on the other side, and getting creative with grips etc...
verbalist54
