Van and Truck Part compatibility
Fleetwood
Kansas
I
Hello! I am having issues with my 1987 K10 (350 TBI). I have access to a 1995 G20 van that also has a 350 TBI engine. Are the ignition and computer parts on theses engines compatible with each other? Thanks!
Are you wanting to use the engine, or the electronics?
Fleetwood
Kansas
I
The electronics like the ECM, ESC, pickup coil, and sensors like O2, coolant, and knock
Most of that stuff will be the same, except I believe the ECM will be different. Harness of course will be different since it's a van and the ECM is mounted under the driver's seat.
zapattack
