v-6 and v-8 crossmembers the same?
Big Moe
dallas
moises
Engine crossmember??? Are you referring to the complete system with the A frames and all?
No, I was give wrong info. Disregard, I had to go see for myself. It's a brace that runs across the frame near the radiator.
Big Moe
dallas
moises
Thank you for the response
MikeB
I just went thru this when swapping out a 250 six for a 350 in an 82 C10. My biggest problem was determining which small block engine brackets (aka clam shells) to use. There are a bunch of them, and they all have slightly different dimensions.
I lucked out because the frame brackets are the same P/N for both engines, but the motor mounts are bolted higher on the brackets into a second set of holes.
Anyway, for anyone wanting to know what P/Ns were used in which year models, etc., this site was very helpful to me:
http://www.gmpartswiki.com/
To find engine mount bracket P/Ns you can do query on "bracket, engine mt" and enter the correct year, and you get a bunch of manuals and pages to choose from. Sometimes you'll get pictures, other times just the part numbers and descriptions.
BTW, GM calls the frame brackets "bracket, engine mt frm".
zapattack
